As we bought the PSG 8267D I was disappointed that there was no driver available in ADS.
For the PSG 8267C there is... but I hope this will also be the case for the D version.
Is there a workaround so we can use the PSG 8267D in the ADS environment????
See the following for more details:
"ADS 2006A Connection Manager(CM): In addition to the existing Ptolemy Sinks to download signals to the Agilent E4438C (ESGC) and E8267C (PSG-C) sources, does ADS CM also support links to the following contemporary Agilent sources: E8267D (PSG-D) and N5182A (MXG)?":
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&_schema=PORTAL&itemid=270783&search=E8267D&ref=search
Mark (EEsof ADS Tech Support Engineer)
