Is this the place to ask RF budgeting questions? I'm having trouble with a simulation.
I've started using the Budget_BaseLine example, and could run that correctly. Then, I removed the RF PA model, and copied the amplifier model to the input, so I have
Port1-Amp-BandpassFilter-Mixer-LowPassFilter-Amp-Term2
Now, when I run the simulation, I get an error message in the terminal window that
" UnboundLocalError: local variable 'S11' referenced before assignment
hpeesofsim terminated due to an error "
Any suggestions?
Thanks
Dave
Any suggestions?
Thanks
Dave
