Hello All,
Does anyone know if Momentum supports Multithreading. Can one run it on a multiprocessor machines or not. If yes can you please provide some detail on what needs to done in order to get to run properly
Thanks
Thanks
However a part of the solution process, i.e. the "Green function caluculation" and the calculations needed to "build up" the above said matrix could be actually parallelized... ::)
