Hi!
I am running ADS2005A on a Linux machine. I would like to visualize the calibration lines so I added the line
MOM3D_USE_VISIBLECALIBRATION=TRUE
in the file momentum.cfg in the $HOME/hpeesof/config directory as suggested by the document entitled "Understanding and Adjusting Calibrated Ports in Momentum". Unfortunately nothing was displayed. I tried with both thick metal and sheet metal.
Do someone have the same problem?
Thanks a lot
Francesco
Thanks a lot
Francesco
Can this option be turned on from the Expert tab in the EM Setup?
I need admin privileges to edit the config file.
