hello
i'm using the uwb designguide, especially the designexample uwb with narrowbandinterference.
there ,a variable tstepwlan is defined, but i don't see the direct influence .diversifying the value makes no change in the interferencespectrum /datadisplay .
in the documentation i could only find the information that the 802.11b source reads data set from data set file WLAN_80211b_8Xoversample.ds. and uses a ratio that adjusts its time step to be equal to TStep.
in my simulation the bandwidth is 12.5GHz/TStep 40psec what tstepwlan is necessary that all components work correct.
thanks in advance
thanks in advance
