hi,
I'm learning the dynamci link interface between ADS and Cadence. I'm going through an example on RFIC Dynamic Link Manual but I've run into a problem. When I do Dynamic Link-->Design Variables-->Get Design Variables ADS tells me 'No Design Variable found' even though I checked in Cadence schematic and Design Variables are listed under Dynamic Link-->Design Variables...
Have any idea what is going on? Thanks
In ADS-DL, when importing design variables into the ADS schematic. Only the designVariables in the view you pointed at, will be transferred into ADS.
You can place all the designVariables in the topView in Cadence, prior to work in ADS.
If this issue persits, you are welcome to contact me via our Tech support team: eesof_support@agilent.com
