I'm using the UWB Designguide and I want to define a user-defined waveform inside a pulse generator, but I don't know how to do that. What I'm doing: I open the example UWB_Test_Bench which contains a Pulse_shape_generator. Inside this generator, only four pulse shapes are selectable, but I didn't find a way to add a user-defined one.
If somebody can help me, I would be very happy.
Thank you and best regards.
Jens
Jens
From the main doc page, follow the link called "Model Development", then "User-Defined Models", then "Building Signal Processing Models" and "Writing Component Models" sections.
