I'm trying to make a simple amplifier IP3 test (using the Harm Bal). My signal is 2450MHz and I use two test tones at 2452MHz and 2454MHz. The amp IIP3 is -20dBm and its gain 20dB. Signal is -60dBm and test tones -50dBm. I'm therefore expecting at the output of the amp an IM3 at 2450MHz with a power of -90dBm and my signal at the same frequency with a power of -40dBm. However, creating a mix table, what I get is an IM3 with -40dBm (should be -90dBm!!!) and a signal with -400dBm (should be -40dBm)! All signal number of harmonics is 3, max mixing order is 5 and I don't get any warning message. If I slightly shift the 2nd tone in order to have the IM3 to fall slightly beside the signal, the results are correct though.
Can someone explain me what's wrong?
Regards
Fred
Regards
Fred
It seems to me that you have three tones in your simulation, is this correct?
