This is a question on "ADS: How to control ADS from another application? (Using ADS AEL script approach)" (doc ID: 146525).
If I just use the code as stated in the doc ID 146525, the simulation cannot really finish before the ADS quit. Do I need to insert a "api_set_timer" function as used in "usermenu.ael" example?
Doc 146525 doesn't elaborate on this. I found another doc 150.759, but I couldn't start hpeesofsim.
In unix environment, it gave error "hpeesofsim: while loading shared libraries: libgem_parser_spectre.so: cannot open shared object file: No such file or directory"
in PC command line, it gave "ptgem.dll" not found.
Xu
Xu
