Hi all!!!
I have the following problem:
my verilog code has more than 100 input/output pins.
I associated a symbol to it, created via the Create/Edit schematic symbol. When I try to use the component (and then to compile it for the first time), ADS crushes.
Could someone please tell me if there is a limitation of the number of pins that can be successfully used?? my feeling is 99 (and I tested a 99 pin component) but then my verilog block will never work.
Thank you for your attention
The problem could be in the AEL code for the VerilogA subcircuit.
Please contact your local EEsof Technical Support for further assistance in debugging this.
