I have made a lot of pratical circuits with ADS and I have compare the results with the Momentum simulation and all was all right.
I try to make a INVERTED F antenna. This antenna must not have a ground plane. I have make the simulation to have an minimal return loss at 2,4GHz.
The problem was that the pratical circuit is not in accordance with the simulation. Is something that I must know to this simulation.
Thank you very much for help me....
