Hi All,
when using the thick metal expansion in momentum, the thickness of the dielectric layers in between each metal strip is increased only where there is some metal or is uniformly increased for all the layout? More explictly, if I have places where many metal layers overlap and places where there is only the top metal, is it correct to assume that the substrate is thicker even beneath the top metal?
Thanks a lot
Francesco
Thanks a lot
Francesco
thanks
thanks
