Hello.
My 54845 a fails time base and pattern trigger on self test. I`ve tried all over for a year to find a new or used acqusition board but without any luck. I have no schematics or layouts of components for the unit at all. So it makes it kind of impossible to troubleshoot to. Is there anybody out there who knows this unit well and will be kind enough to guide me in the right direction. Is there a download link for schematics for the 54845 A.
I`ll appriciate any help.
Thank you.
Thank you.
Thak you for your ansver, but it did not help our problem.
Our HP 54845 A fails on self test.: Trigger Level, Pattern Trigger, and Time Base.
Acording to troubleshooting tree the acqusition board schould be replased.
Please advice.
Best regards
Pingvin Kuldeindustri Ltd
Magne Oknes
Thank you for responding. The Agilent representative here in Norway suggested the same as you did but back in 2009 after i bought the unit on eBay and realised it was a lemon. They diden`t have 1.44 MB floppy disks to reinstall so they sendt the harddrive to Germany for reinstallation/update. But it diden`t help. The unit calls for self calibration but it hengs after a while and has to be reset. The same thing on auto-schale. It hengs and no tasce for any channel appares. It never did.
It fails on self test on the folloving:
FISO. Needs recalibrate to remove data bit error. No mux gain change measured. Test Gain Failed. Fails on Line Trigger. No trigger found in line trigger source mode. Test trigger level failed. Test Pattern Trigger Failed. Test Timebase Failed.
Out from that. Is it the acqusition bord that is at fault. If so. Can it be repaired? You seam to have very good knowledge to a veraity of HP testequipments and I`ll appriciate your help fyrther very mutch.
Happy Easter.
