After applying System 5.00 and associated Library and Graphics firmware updates to my DSO6034A I discovered that the Quick Print functionality had been disabled.
Furthermore, the Print Configuration menu button has completely disappeared from the Utility menu.
After the Sys 5.00 update pressing the Quick Print menu button displays "Print to <None>". And nothing happens when you press it. Before the update it would write to the inserted USB memory stick.
So now I can't use the Quick Print function for anything.
Can you "roll back" to an earlier system?
"Usability enhancements for the print and save/recall configuration menus."
Could it be that the way it works has been changed in a non-obvious way..?
Might be worth a look in the updated user manual.
As an aside, I find that now you can get a screen image over the web interface I don't use the print to USB stick option.
