I am wondering if anyone could recommend the best method to synchronize two DSO series oscilloscopes which are located 10km apart.
The two scopes are to sample the signal every minute.
Currently, the data acquisition is automated using Labview 8.0 and we have two units of GPS receivers from Garmin.
We know that there are other hardwares that we could acquire to perform this task accurately but we preferred to use these two scopes instead.
We could not figure out how to do the synchronization properly with minimum time mismatch.
Any suggestion will be highly appreciated!
Alan
Alan
I am wondering if it is possible to connect the PPS output of a GPS receiver to the external trigger port on DSO5034A to synchronize the two scopes?
Has anyone try this before? This will overcome the software delay.
