I am trying to transfer the waveformdata to the PC by VEE using all 8M memory.
With Channel1 and 3 on screen it is working and I get 8M points for each channel.
If I try it with only one Digital Channel (D0) on screen I only get 4M points. My commands:
":STOP"
":WAVeform:POINts:MODE RAW"
":WAVEFORM:FORMAT BYTE"
":WAVeform:POINts 8E6"
":WAVEFORM:SOURCE POD1"
":SINGLE"
":ACQuire:POINts?" says 5M points
":WAVeform:POINts?" says 4M points
What do I have to do to get 8M points?
Thanks
Christoph
":STOP"
":SINGLE"
Thanks
Christoph
you are getting the maximum number of digital points if your sweep
is in the range of 1ms/div to 20ms/div.
