Hello everyone
I've a DSO8064A scope with lowspeed options and 4Mpts. Today I've try to make a SPI measurement with decode enable, using all 4 channels.
If I use 3 channels (clock, CS and MOSI) the system working fine and the decode is correct; when I try to use the last channel (MISO), set the decode option, after a regular trigger signal the scope go in error (crash) situation and show the dialog message:
Error in agscope.exe ver: 5.71.00 ....
offset 001A84C0
Same with software 5.50.0001
Any idea ?
Daniele Banfi
offset 001A84C0
Any idea ?
Daniele Banfi
There are many scopes available now, from Agilent, that support SPI, and do it much better than the 8000 family ever did.
Al
