I have some problems to properly generate arbitrary Signals with my U2351A. I use c-code (with VISA) and try to load data with the DATA #40024 <byte1>.... command. Is there not an example around? Best would be by using two channels.....
thanks
thanks
for an appropriate forum for the U2351A but there does not seem
to be one set up. You might try the Agilent Contact Center or Test
and Measurement Tech Support for an answer to your question.
