I'm trying to use the "symbol" read out mode for the digital bus display. i.e.
Setup/Digital/Bus N/Read Out = Symbol
As the help says I have created the files c:\scope\config\bus1.txt and c:\scope\config\bus2.txt etc. However, if doesn't matter what I put in these files, the output on the scope doesn't seem to change. I even tried cutting an pasting the example. Restarting the scope doesn't help either. Any suggestions?
Scope firmware is 5.30.
Cheers,
Jon
Cheers,
Jon
I was able to get this done. I am enclosing a screenshot alon with the portion of the bus2.txt file that made it work. Hope this helps.
edgardog
