Hi
We are characterizing a 3.2Gbps link and we are analyzing the jitter spectrum to understand the effect of few spectral components. we are using Aglent DSA91204A scope in the lab.
We want to do some math on the spectrum and hence would like to extract that FFT data into a excel sheet or text file. Can someone please tell me how I can extract the data?
Regards
rajkumar
Regards
rajkumar
You don't say whether you want to do this manually or programmatically. In either case, the FFT is just another waveform.
Manually, you use File->Save-Waveform. Choose a file type of 'XY Pairs Files (.csv)', enter a file name, choose 'Jitter Spectrum' as your Source, then 'All Data'. Click Save and you're all set.
Programmatically, use :WAVeform:SOURce MSPectrum, then :WAVeform:DATA?
Al
