In my example the rising edge of the digital channel D1 was used for triggering. My question is: Why the trigger point and the rising edge of channel D1 do not coincide (see Figure)? Did I make a mistake?
Christoph Wosnitza
Christoph Wosnitza
The other difference that you might be seeing is the 8 bit ADC on the analog channels versus the 1 bit ADC on the digital channels. This can cause a slight delay on the digital channels versus the analog channels.
