Ok, so using Hyperterminal I can connect to instrument and it sends correct data. However, with Agilent Connection Expert I about half of the characters are replaced with questionmarks. I tried to compare the serial traffic using PortMon and the only visible difference is with the masks. How can I change the usage of masks in Agilent VISA or is there some other probable cause of the problem?
