Hi, I have saved a scrap HP 54600B scope from work that works perfectly other than no control over vertical trace position on either channels. As I can't find a replacement board, I was looking for any hints ore maybe a schematic of the control board with the position knobs and v/Div switches.
I have run the control test program this to shops both controls unresponsive.
Any help would be received gratefully.
http://www.home.agilent.com/agilent/edi ... id=1517718
This is the CLIP, Component Level Information Package, for the 54600A and 54601A oscilloscopes. It includes parts list, part locator, schematics, and block level theory. It does not include power supply schematics.
These pages are scans from a large page format, so you must print the pages and assemble them in order.
Parts may no longer be available from Agilent.
These schematics can also be used to get close to root cause failure on the similar 54600B, 54601B, and 54602B oscilloscopes.
