I would like to use the oscilloscope to trigger another instrument after 2 events are recorded and the time difference is calculated. So far I've been unable to find a starting point for how to do this. Can anyone help?
Lisa
Lisa
Could you explain more about what you are trying to accomplish? I will list a few starter questions.
1. Are you capturing two different signals on two different channels on the same trigger event? Or, are you using only one channel and you capture a waveform on each of two different triggers?
2. What is the calculation you are doing between the two waveforms? Is the scope making the calculation or are you doing the calculation off line using a program?
3. Is this whole process automated using programming commands?
4. Can you add a screen shot showing the scope display to help illustrate what you are trying to accomplish?
5. What other clarifying information can you give me so that I better understand what you are trying to accomplish.
By better understanding your application, we will not not make the wrong assumptions and go down the wrong path.
