I was going through the data-based amplifier/behavioral model example called AmpH1H2_prj.
What is the main benefit of using the AmpH1H2 model instead of a regular HB simulation of the original circuit block (like the circuit_level_amp_SOITOI.dsn)? It seems since this element only accurately models up to second order, it is limited in its application.
