I am attempting to do a transient simulation on an closed loop oscillator, with no sources connected other than the dc supply. I also have a transient sine wave signal source connected to a resistive load in the schematic. Neither the transient source nor the resistive load are connected to the oscillator.
When I change the signal generator's frequency and amplitude, I get different results for the transient simulation of the oscillator. If I
remove the signal generator from the schematic, the oscillator results also change.
Any explanation/suggestion as to the reason behind this would be greatly appreciated!
http://eesof.tm.agilent.com/support/supp101.html
