Hi, Is there someone knows how to import data file in Data Display.
I want to plot a X-Y file in Data Display window and compared it with the simulation result.
Is there any way or other workaround?
Thanks!
Thanks!
File>Import>Import dataset using instrument server
You didn't say what format your X-Y file is in, but in the InstrServer/MainWindow, you will need to select "READ" & Read From "File". Formats avail are Citifile, Touchstone, and MDIF.
You then browse for and select the file to read, and enter a name for the dataset you will write back out. So you will then generate an ADS dataset which the Data Display window can read. When ready, push the "Read File" button on lower left of panel to perform the operation.
For more information, see the ADS help file user manual: "Design & Display, Using Instruments, Instrument Server, Reading from & Writing to Files"
http://eesof.tm.agilent.com/docs/adsdoc2003A/instrumentio/index.html
You can also search the Knowledge Center database for "import data display" for some good information. There is even a description on importing data from an Excel file.
Hope this is helpful to you. :)
