I am having bit of trouble simulating coaxial resonators in ADS.
My resonator specifications are;
Impedance :6.02Ohm
Freqency: 460MHz
Er :98
Q :330
Plating : Silver
The values I entered on TLPSC;
Z : 6.93Ohm
L :0.648 in
K :98
A :1.2 dB/m
F :460MHz
TanD : 0.00
Mur :1
Tan M : 0.00
Sigma : 0
I have used the Transtech application guide to calculate this values. http://www.trans-techinc.com/appnotesPDFs/No1009.pdf Can some one confirms these are correct.
I am not getting enough notch depth in my simulation using the above TLPSC model.
Impedance :6.02Ohm
Freqency: 460MHz
Er :98
Q :330
Plating : Silver
Z : 6.93Ohm
L :0.648 in
K :98
A :1.2 dB/m
F :460MHz
TanD : 0.00
Mur :1
Tan M : 0.00
Sigma : 0
I hope this helps.
