During S-Parameter simulations with the topology check set to "yes" in the Options block, I get the following error message:
Error detected HPEESOFSIM in topology check during circuit set up.
The following nodes have no DC path to ground.
_net1615
_net1614
Okay, I give up, how do I display the net names of the nodes so I can figure out where the problem is?
_net1615
_net1614
Hence the location of "Highlight Node..." under the simulate menu. Same reasoning applies for "Annotate DC solution", etc.
I have assigned hot-key "control-h" to "Highlight Node..." :)
