There are a couple example User Defined Applications. These should get you started in your User Defined Application experience. These are examples around the using BASIC and Advanced mode.
Sir, I would like to know how to develop UDA for DSA91304. I am not able to use the information provided in this thread. So please provide the information regarding the UDA development for DSA91304.
There is a pretty good tutorial built into the SW. It walks you through the process of creating your first application, including how to set up the file system and test your app.
Note that you DO NOT need a license to create an application. This is generally done on a PC. You DO need a license to run a created application on your oscilloscope.
Try the tutorial, and ask questions if you get stumped.
Sir, I have gone through the tutorial provided with s/w development tool and now I am having doubt regarding external application control. Can you please explain how to control an external application using UDA environment.
What have you tried? What investigations have you done?
I just looked at the manual and the sections on "Using an External Application" and "Managing External Application Scripts" seem pretty complete to me.
Regards.
