What would be the easiest way to simulate the RF filter path impact to RMS phase error? GSM signal is fed to RF filter and it's effect to GMSK modulated signal should be simulated.
How it is done with EDGE (8PSK) modulated signal? I would like the get EVM RMS, peak-avg and 90th percentile values?
Could somebody give advice?
"Tools>Examples Search..."
Then in the query, type "edge_evm" 8)
You will see results for two projects of relevance:
EDGE_RF_Measurement_prj
and
EVM_Examples_prj
These projects utilize dedicated EDGE sinks from the EDGE Measurement palette, "EDGE_EVM" & "EDGE_EVM_with_ref".
The help files for these components I think will show you how to get your RMS, peak, and 90th percentile numbers. :)
I hope this is helpful to you.
