I need some examples of how to use the "AM_DemodTuned" and "FM_DemodTuned" items.
Specifically I'd like to have an example where an "AM_ModTuned" block is used to modulate a 100 MHz signal with a 1 kHz tone and then an "AM_DemodTuned" block is used to demodulate it. Likewise for FM.
There are no examples (that I can find) for the use of these blocks (AM/FM_DemodTuned) in the knowledge base.
Also I'm interested to find out if there is a way to compute SINAD using the analog simulator (I don't have Ptolemy).
Can someone help me out?
