I would like to know whether the DAC component can be used with a measured input variable, e.g. the output voltage of a detector during the simulation, insead of a variable specified before you start the simulation.
I am trying to implement an AM/AM and AM/PM characteristic. I tried the standard components with s2d and p2d data. These components do not lead to the correct results if you are feeding them only with the n21 data and omitting n11, n22, n12 data.
Thank you for any hint. Wolfram
Here's some examples:
You will need to come up with the equations for the SDD to propely model the desired characteristics based on the file data.
