Question: Has anyone successfully simulated analogue frequency dividers in ADS2002?
Background: I am trying to simulate a simple analogue frequency divider circuit using nonlinear elements (in this case a varactor) and some resonant circuits at the input and output frequencies. However I cannot see the subharmonic generation. I have tried both HB and transient, but don't see where the problem is! Any ideas?
If that is NOT possible, then please share more information in this forum. Let us know, all the parameters you have set in the simulation controller (HB) and how the sources are setup and what sort of components you are using to create the varactor?
Thanks
nilesh 8)
