Can a Sweep Plan be passed to a design ?
Question asked by fcolomb on Jul 7, 2003
Latest reply on Jul 7, 2003 by fcolomb
When several designs need to be simulated with the same frequency list, is it possible to use a single Sweep Plan component?
I would guess that the path to the Sweep Plan needs to be available from each design ?
I tried placing the Sweep Plan in a separate design and then in one of designs containing a network I selected Options/Variables to set the Top Design in Hierarchy to the design with the Sweep Plan.  When the circuit is analyzed it runs at just one default frequency thereby not recognizing that I intended to use the Sweep Plan.
I am looking for a solution not involving Test Labs.
Please, any suggestions ?  Thank you.
