What Altera JTAG cables work with FPGA dynamic probe? and Can I use the FPGA dynamic probe application to download configuration bits into my Altera FPGA?
Yes you can use FPGA dynamic probe application to download your bits to your altera FPGA.
As far as the JTAG cables, you can use the following
Altera ByteBlaster, USB Blaster and MasterBlaster cables. The cable makes a connection between the parallel or USB port on the logic analyzer and the JTAG pins on the FPGA being measured.
