I have a reason to want to be able to boot from the floppy whenever the floppy (with system)
is inserted into the drive and the unit re-booted.
Is it possible to force the analyzer to boot the OS from the floppy/hard drive? From
my understanding, *if* the flash memory is detected to contain a valid OS,the system
will always boot from the flash. Should the flash be detected as absent or corrupted, then
the system will boot from the floppy. Am I correct on this? I would have thought that the
system would always boot from the floppy should it find a valid system residing on the floppy.
If the system will boot from the floppy regardless of the flash memory, what is the procedure
for creating a boot disk.
thanks
Jim
thanks
Jim
