I just got a 1652B from my boss at work, primarily because it won't turn on and the power supply continually clicks and makes a small hissing/sizzling noise. I was assuming that it was a transformer problem, but the transformers don't get very warm, or seem to dissipate any heat at all. Stranger still is that the first time I took it home and plugged it in (which was probably the first time in several months that it was powered up), it worked fine for a few minutes, then just shut off.
Anyone have a professional opinion about this? Does this sound like a transformer problem? Or maybe some dried out caps? I don't see any leaking or bulging on any of the caps, but they could've died from old age.
Thanks!
Thanks!
