MXA N9020A Digital Demod: Retrieving SYNC SEARCH result
Question asked by mifreeman on Mar 9, 2009
Latest reply on Apr 10, 2009 by jborges3
I'm trying to locate the correct GPIB command that will return the result of a Digital Demod Sync Pattern Search (SYNC SEARCH).
Previously, using the 89441 VSA, you could simply query the Questionable Modulation Register, using the GPIB query: STAT:QUES:MOD:COND?
However, the Questionable Modulation Register does not exist on the N9020A MXA.
Is there an GPIB command that, will allow me to determine when the "SYNC NOT FOUND" condition exits on the MXA?
