While testing EVM using N9020A MxA, "Sync Error" is continuosly observed.
Could not find any information about this error or it's resolution from MxA manuals.
The MxA is being fed a GMSK signal in the RF port, 13MHZ external clk is connected to "Ref In" port, and 216.66Hz(Frame Clk) provided in Trigger1 In port. MxA has been configured accordingly for these inputs.The 13MHz clk and trigger signals have been verified using a Freq. counter.Also, what does the "RF sync delay" option in the MxA signify?
Thanks in advance for your reply.
Are you using the 89601A application, or the N9071A GSM/Edge application?
