I want to calibrate 346C option K01, upper frequency to 50GHz, please suggest what the standard instrument I should buy ? I have 8975A and N2002A for now.
Unfortunately, due to the complex test equipment involved, there are no recommended performance tests for the user to perform on 346CK01. There are also no adjustments that can be made on these noise sources by the user.
Please return these noise sources to Agilent Technologies when tests are required to verify its performance and for periodic re-calibration.
Best regards,
