Hi, Can anyone recommend any ATE/ICT Friendly Fux & Solder ?
We are currently using Indium Corporation of Europe WF-7742 VOC Free Flux and BLT Nitro Flow 63/37 8830609 (Leaded) solder in our process.
Our main running PCB utilises 1.4mm size round test pads (700 nodes in a 700mm x 100mm surface area)with a HASSEL finish. From time to time we get the odd test pad (On two identical ECT fixtures)that does not connect with our ICT machine (i3070) and as a result of First time pass rate is hovering around 98.3%. In order to inprove our process further we have tried many different types of test probe in the two fixtures. Examples of which are:
QA Probes
100-25 Series 08 Triad 8.1oz
100-25 series 63 Chisel 8.1oz
Coda
Pogo 25I35-6-S
Beadon
100PRG2591H-S Blade and some 6oz pre loaded probes used for lead free.
In all cases they all appear to perform around the same, even with the automatic fixture bounce and retest on. This is why we have turned our attention to the process inparticular the Flux & Solder finish.
If anyone has any other suggestions or other ideas on how to improve our process further, this will be greatly appreciated.
Simon
QA Probes
Coda
Pogo 25I35-6-S
Beadon
Simon
Seems like a question more suited for the paste guys, so can't really comment. One alternative you may want to consider is bead probes. (www.agilent.com/see/beadprobe)
But unlike building bead probe in the traditional manner (i.e on traces) you can place them on test pads making effectively a bulging testpad. This gives more volume/surface and thickness to it and you can use a more aggressive test probe then? Also i remember reading of a list of solder paste recommendations for bead probes (which are ICT friendly) somewhere in this forum.
