Skip navigation
Register
Home
Forums
Blogs
Help
My Links
My Bookmarks
My Questions
My Places
Log in
0
Search
Search
Search
Cancel
Error: You don't have JavaScript enabled. This tool uses JavaScript and much of it will not work correctly without it enabled. Please turn JavaScript back on and reload this page.
All Places
Discussion Forums
Signal Analyzers
Questions
Log in
to create and rate content, and to follow, bookmark, and share content with other members.
Answered
Assumed Answered
N9340A trace data
Question asked by
andrew.baylon
on May 5, 2008
Latest reply
on May 8, 2008 by andrew.baylon
Like
Show 0 Likes
0
Comment
2
Anybody knows the commands to get trace data from N9340A remotely.
tnx...
This content has been marked as final.
Show 2 comments
Name
Email Address
Website Address
Name
(Required)
Email Address
(Required, will not be published)
Website Address
jborges3
May 7, 2008 6:11 PM
Mark Correct
Correct Answer
Hello Andrew,
Use the SCPI command Trace:Data? This command will return the trace data in ASCII format.
The support engineer for this product informs me that this command was added in a recent version of firmware, so you may need to update your FW for it to work.
Best regards,
andrew.baylon
May 8, 2008 11:13 PM
Mark Correct
Correct Answer
thanks for the reply.. I already found the answer.
use first ":TRACE1:MODE VIEW" then follow with ":TRACE1:DATA?"
Best regards,
