I have a problem, program still runs but i can't save the image to my PC. I can save it in the Spectrum Analyzer E4405B device though. What went wrong?
You might try using all capital (uppercase) letters in your path and file name when saving the file on the ESA and then when requesting the file back. I saw this cause a similar issue on the PSA when I worked on the program for it.
i tried changing file path, filename to capital letters but i still see blank image. What's next? Appreciate any help given. Thank you
