Hi All,
i have a problem with a test setup i am using. I have a diecast box that contains a PCB with the DUT mounted inside it. I am measuring leakage current with a power supply and electrometer.
The problem i have is that the diecast box is being used as a return path for the signal because the BNC sockets are chassis mount. now i have read that it is good to ground the chassis of your fixture to prevent noise pickup etc but i am worried about electric shock since i am using high voltage. Look at the diagram for a better understanding.
Should i be worried about electric shock, and will i see any more noticable noise pickup from using the chassis as part of the return(GND) circuit.
Thank You
Thank You
