I am running a fixture that has been in production for a number of years. It is testing a panel of (2) and the second board always fails. I am unable to swap the boards to see if it fails in the alternate location. I have swapped the fixture to our other base unit, and this issue follows the fixture. Everytime we test, the board fails and the printer shows:
2:u8:u has failed
subtest: unit2_open
status: 2H
Auxiliary Source Current Compliance
This fails under the analog powered test. I have tried running in pushbutton debug, and the message is that all tests passed (or were not run) and to refer to the window for further details. The window shows this error. I found some resistors in the fixture, but they all seem to be reading fine and connected fine.
Would anyone have experience or know what to look for to fix this?
2:u8:u has failed
subtest: unit2_open
status: 2H
have you install new software?
regards sepp
