I got an ICT fixture and program transferred from another site. It worked fine there, but failed TestJet here.
It failed everything tested by TestJet indicating that this test doesn't work.
I checked the board config file. It matches with the tester's config file.
I run the same test software both on Windows and Unix. The failures are the same: TestJet doesn't work. Everything else passes.
Can some one give me some clue what else I should check? Thanks in advance.
I double checked the board config file. I found it enabled advanced fixturing for which my tester doesn't have this feature. Also, when I recompile the "fixture" file, I got a lot of errors. Is this the reason that causes the TestJet failure? Thanks.
