I have a problem with one ICT machine.Until know i was connecting locally on the computer , now when i try to connect on network domain the BT Basic application does not work properly, it's starting but it's not vissible it's like running in background.
What i noticed is that everytime i log in as a different user an application it's starting which seems to configure the XVision profile.
I took a look on Control Panel , XVision Profiles and on the Global Setting tab there is a field called Authorized Hosts. For the computer that is not working this field is empty.
On the below link there is a photo with this field for a computer that has no problem running Bt Basic.
http://imageshack.us/photo/my-images/81 ... issue.jpg/
Does anybody have any ideea what could be the problem?
Thank you in advance.
If XVision did not start, please start the "XVision Server" by clicking
Start->All Programs->Vision->XVision Server
Take note that "Startup" is in the Documents and Settings\All Users\Start Menu\Programs\ such that all local/domain logins will start the services that needed for ICT software to be working properly.
The "Startup" consists
- Data Logging transfer
- IO Control
- rmiserver
- Vision Services
- X Colormap Initialization
