I have a working I/Q capture going by the example code in chapter 2 of the Basic Mode Guide for my E4440A spectrum analyzer (thanks for previous help on this). But no matter how low I drop the sample rate, I get a time out from visual basic when I do a deep capture if I have the capture time greater than about 1.5 seconds. It times out between these two lines of code:
psa.WriteString ":INIT:TCAP;*OPC?"
opcValue = psa.ReadString()
So my guess is that the spectrum analyzer does not respond fast enough after the capture has been initiated by the computer. Is there any way to prevent this so I can do longer captures? I tried separating the INIT:TCAP and *OPC instructions and putting a pause in visual basic in between them, but that did not work.
Thanks for the help.
Is there another instruction I have to include so it does not have trouble going above 3 GHz center frequency?
