First of all, sorry my english.
I need to check a non jtag component with a Nand Tree test and I don't know how can I do it. Does anyone have any idea of that?
do i need specific information (like a bsdl file for example) to do this test? Is a normal library?, ...
Thanks in advance for any information.
Regards, Jose
Regards, Jose
You need the Nand tree information of the device you are testing. The Nand tree test can be easily generated using a script. The script NTREE.BAS and NTREE.AWK is in the C:\Agilent_ICT\contrib\bin while the user ntree.doc is in the C:\Agilent_ICT\contrib\doc that explain how to use the script. The scripts are only available in the contrib on a PC version from 07.00p and above
Regards
Jun
